configure cfm domain association delete
configure cfm domain domain_name association association_name [ports port_list delete [[end-point [up|down]] | [intermediate-point] ] ]
Description
Deletes a maintenance end point (MEP) or maintenance intermediate point (MIP) from that MA.
Syntax Description
domain_name
Enter the domain associated with the MA you are configuring.
association_name
IEEE 802.1ag or ITU-T Y.1731 association name
port_list
Specifies the port number(s).
up
Specifies that an UP MEP is to be deleted.
down
Specifies that a DOWN MEP is to be deleted.
Default
N/A.
Usage Guidelines
Use this command to delete an MEP or MIP.
If the VPLS option is chosen then the CFM deletes all the VPLS-based MIPs.
Use the show cfm command to verify your configuration.
The following command deletes port 5:12 as an MIP on the test association in the brazil domain:
configure cfm domain brazil association test ports 5:12 delete intermediate-point
The following command deletes an UP MEP on port 5:10 on the test association in the brazil domain:
configure cfm domain brazil association test ports 5:10 delete end-point up
This command was first available in ExtremeXOS 11.4.
Platform Availability
